Use this guide to lead in the replacement of your HP TouchSmart 15 screen.
Acquire the metal spudger and a Precision Magnetized Driver with J1 size bit.
Flip your HP TouchSmart 15 over.
Locate tabs on the underside of the laptop.
Push both tabs towards the center of the laptop and pull away to remove battery.
Take the sharp end of the pry tool and pop out the black screw cover.
Repeat on opposite side.
Take the Precision Magnetized Driver with J1 size bit and unscrew the screw.
Using the pry tool, begin to separate the touchscreen from the plastic backing.
Close the laptop and flip it over once again.
Continue to pry the touchscreen from the plastic backing in the hinged area of the laptop.
Flip over the laptop and open it.
Pull up on the separated touchscreen while pulling it away from the plastic backing.
Lay the touchscreen on the keyboard facedown.
Locate the connection point.
Slowly and carefully peel off.
Isolate the touchscreen from the keyboard.
Begin by peeling off the black adhesive tape using the pry tool.
Once adhesive tape is removed, use the pry tool to remove the tab in the corner. Repeat in each corner.
Using the sharp end of the pry tool, separate the plastic from the screen.
Now it is time to reassemble your device with a new screen.
crwdns2917034:0crwdne2917034:0
Amazing work. I would not change a thing.
