The HP TouchSmart 15-r015dx has a standard laptop motherboard.
Flip over to view the bottom of the laptop in order to gain access the battery and the DVD±RW Drive.
There are two battery release switches circled.
slide release switches inward towards each other to release battery.
after sliding the release switches, pull battery towards yourself to remove battery.
There is one screw holding the DVD±RW Drive in place. Use the #00 screwdriver to remove the screw.
The DVD±RW Drive is here. Remove by gently pulling it straight out.
After removal of the DVD±RW Drive, two screws are exposed and must be removed.
Using your Phillips #00 screwdriver, remove the two screws to loosen the fittings of the keyboard.
Flip the laptop over to view the top and lift the screen up.
There are sixteen clips holding the keyboard in place. Gently pry up each clip using a plastic opening tool. Once all clips are loose, lift the keyboard from the computer.
Flip the black latch up to release the film-material. Once flipped up, simply pull the film-material out from the laptop to release the keyboard.
Flip the laptop over to view the bottom and remove the remaining screws from the bottom.
Flip your laptop over to view top and open it.
Remove the four screws and the two wires before removing the base of the laptop.
Use your plastic opening tool to pry the base of the laptop off.
There are two screws holding the hard drive in place. Remove these screws.
Remove the hard drive by pulling it to the right like shown.
There are 3 screws holding the motherboard in place.
Unscrew the screws to release the motherboard.
There are several wires that need to be disconnected from the motherboard.
Remove the wires carefully.
After removing all the wires, pull the motherboard out.
I need to buy this motherboard online
How can i find it?
