HP TouchPad Motherboard Assembly Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. HP TouchPad Motherboard Assembly Replacement, Motherboard Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If present, remove the two pieces of tape boxed in red.
  2. HP TouchPad Motherboard Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP TouchPad Motherboard Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the edge of a plastic opening tool to flip up the retaining flap on the volume control/power button ribbon cable socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the cable out of its socket.
  3. HP TouchPad Motherboard Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to lift the camera connector up and out of its socket on the motherboard.
    • Bend the camera cable away from the motherboard.
  4. HP TouchPad Motherboard Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP TouchPad Motherboard Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully flip up the retaining flap on the microphone cable socket.
    • Be sure you are prying up on the hinged retaining flap.
    • Pull the microphone cable out of its socket.
  5. HP TouchPad Motherboard Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your plastic opening tool to pry the upper antenna connector up from its socket on the motherboard.
  6. HP TouchPad Motherboard Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP TouchPad Motherboard Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry up the retaining flap on the headphone jack ribbon cable socket.
    • Pull the headphone jack ribbon cable out of its socket.
  7. HP TouchPad Motherboard Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the speaker cable connector up from its socket on the motherboard.
    • Pry up from beneath the wires.
  8. HP TouchPad Motherboard Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP TouchPad Motherboard Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to flip up the retaining flap on the digitizer board ribbon cable socket.
    • Pull the digitizer ribbon cable out of its socket.
  9. HP TouchPad Motherboard Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the lower antenna cable connector from its socket on the motherboard.
  10. HP TouchPad Motherboard Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • De-route the lower antenna cable along the top edge of the battery and carefully pull it out from under its retaining clip near the top right corner of the battery.
  11. HP TouchPad Motherboard Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 3.2 mm Phillips screws securing both the battery and the motherboard to the rear case.
  12. HP TouchPad Motherboard Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP TouchPad Motherboard Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry the battery up from the tape securing it to the rear case.
    • It is easiest to pry up along the edges of the battery closest to the USB connector and the digitizer board.
  13. HP TouchPad Motherboard Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard assembly out of the rear case, minding any cables that may get caught.
  14. HP TouchPad Motherboard Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP TouchPad Motherboard Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the battery away from the L-shaped motherboard to disconnect its cable.
    • Remove the battery from the motherboard.
crwdns2942667:0crwdne2942667:0 1,007
