The midframe in an HP contains a power connector/volume board as well as the mid plate bezel. In this guide, you will learn how to replace the midframe of a HP stream 8 tablet.
Use your nail or a spudger to pry the back cover off of the device.
Slide your finger around the rest of the back cover, lifting it completely off of the device.
Remove ten Phillips #00 screws from the inside cover.
Pry up the inside cover the same way as in the first step.
