If the front facing camera on your HP Stream 8 is broken, use this guide to replace it. This guide requires a battery, unplug the device and power it off.
Use your nail or a spudger to pry the back cover off of the device.
Slide your finger around the rest of the back cover, lifting it completely off of the device.
Remove ten Phillips #00 screws from the inside cover.
Pry up the inside cover the same way as in the first step.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
Remove the front facing camera with tweezers.
