HP Stream 8 Battery Replacement
  1. HP Stream 8 Battery Replacement, Midframe: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your nail or a spudger to pry the back cover off of the device.
    Hey bro are you have a battery for stream 8
    Kashif joiya - crwdns2934203:0crwdne2934203:0
  2. HP Stream 8 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. HP Stream 8 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove ten Phillips #00 screws from the inside cover.
  4. HP Stream 8 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the inside cover the same way as in the first step.
  5. HP Stream 8 Battery Replacement, Front-Facing Camera: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
  6. HP Stream 8 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front facing camera with tweezers.
  7. HP Stream 8 Battery Replacement, Rear-Facing Camera: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
  8. HP Stream 8 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back facing camera with the tweezers.
  9. HP Stream 8 Battery Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the battery connector from the system board using the tweezers.
  10. HP Stream 8 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up on the small black tab to unlock the LCD screen flex ribbon cable using the tweezers.
  11. HP Stream 8 Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the LCD screen flex ribbon cable from the system board using the tweezers.
  12. HP Stream 8 Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the USB flex ribbon cable from the connection point on the system board using the tweezers.
  13. HP Stream 8 Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips using the screwdriver with a PH00 Phillips head.
  14. HP Stream 8 Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard from the device.
  15. HP Stream 8 Battery Replacement, Battery: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 6 PH00 Phillips screws.
  16. HP Stream 8 Battery Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery can now be removed from the device.
    Di mana saya bisa membeli baterai prnggantinya?
    Taman Sutarman (Park Tam Soet) - crwdns2934203:0crwdne2934203:0
Nick Miller
crwdns2935283:004/11/16crwdne2935283:0
669 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 34-14, Maness Spring 2016 crwdns2935289:0Cal Poly, Team 34-14, Maness Spring 2016crwdne2935289:0
CPSU-MANESS-S16S34G14
We're I can buy battery for stream 8 tablet 4000mah
Marlon Ultado - crwdns2934203:0crwdne2934203:0
Bonjour,
pouvez-vous m'indiquer où je pourrais trouver une batterie compatible ?
Bien cordialement
GAVALDA - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,078
