If your HP Stream 8 model 5801 battery needs to be replaced because it has lost the ability to hold a charge, then this is the guide for you.
The battery provides power to the tablet. A faulty battery or battery that isn't able to hold a charge properly needs to be replaced.
Before using this guide, make sure you are using the original HP brand cable and AC/DC adapter. You should also make sure you have the adapter plugged directly into the wall outlet. If you charge your tablet for an hour and still have no charge, continue to follow this guide and replace your battery.
A punctured battery can cause a dangerous fire. If your battery is swollen, please review What to do with a swollen battery.
Before you begin, power down your device completely and disconnect from any power source.
Use your nail or a spudger to pry the back cover off of the device.
Slide your finger around the rest of the back cover, lifting it completely off of the device.
Remove ten Phillips #00 screws from the inside cover.
Pry up the inside cover the same way as in the first step.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
Remove the front facing camera with tweezers.
Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
Remove the back facing camera with the tweezers.
Carefully remove the battery connector from the system board using the tweezers.
Lift up on the small black tab to unlock the LCD screen flex ribbon cable using the tweezers.
Carefully remove the LCD screen flex ribbon cable from the system board using the tweezers.
Carefully remove the USB flex ribbon cable from the connection point on the system board using the tweezers.
Remove the two Phillips using the screwdriver with a PH00 Phillips head.
Remove the motherboard from the device.
Remove the 6 PH00 Phillips screws.
The battery can now be removed from the device.
Di mana saya bisa membeli baterai prnggantinya?
Taman Sutarman (Park Tam Soet) - crwdns2934203:0crwdne2934203:0
We're I can buy battery for stream 8 tablet 4000mah
Bonjour,
pouvez-vous m'indiquer où je pourrais trouver une batterie compatible ?
Bien cordialement
Hey bro are you have a battery for stream 8
Kashif joiya - crwdns2934203:0crwdne2934203:0
