Spudger4.9
crwdns2959928:0crwdne2959928:0 ↓Since HP Stream 7 is a tablet and has many small parts. Be careful when removing/replacing parts. Do not force anything to avoid breaking device material.
Make sure the tablet is powered off before beginning.
Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
Remove the eight 5 mm Phillips 000 screws.
Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
Remove the two 2 mm Phillips 000 screws from the motherboard.
Once unscrewed, the motherboard separates from the rest of the device.
After removing the motherboard, unscrew the four 2.5 mm Phillips 000 screws from the display panel.
Using your spudger, pry the display panel off the front.
The screen should now just come right off. Be sure to catch any broken bits if the screen is damaged.
where can i buy new screen????
eibrims - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Yeah, I want to know where I can buy a screen for my hp stream 7.
Rider Sd - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can i buy a new screen for the stream 7 please??
migueajr - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same question but no answer !
Where can anyone find replacement screen online ??
Ahmed Saleh - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
We're I can buy the replacement screen?
Raymond Borrero - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
