HP Stream 7 Screen Replacement
    1. HP Stream 7  Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 7  Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Make sure the tablet is powered off before beginning.
      • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
    2. HP Stream 7  Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 7  Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the eight 5 mm Phillips 000 screws.
      • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
    3. HP Stream 7  Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 7  Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
      • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
      • If you broke both tabs, scrape the tape and Battery off.
      • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
    1. HP Stream 7  Screen Replacement, Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
      • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
      • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
      • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
    2. HP Stream 7  Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 7  Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 2 mm Phillips 000 screws from the motherboard.
    3. HP Stream 7  Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 7  Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once unscrewed, the motherboard separates from the rest of the device.
      • The speaker is soldered to the motherboard, but it comes off easily.
      • Forced separation may result in a damaged motherboard and/or personal injury.
    1. HP Stream 7  Screen Replacement, Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • After removing the motherboard, unscrew the four 2.5 mm Phillips 000 screws from the display panel.
    2. HP Stream 7  Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your spudger, pry the display panel off the front.
    3. HP Stream 7  Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The screen should now just come right off. Be sure to catch any broken bits if the screen is damaged.
Justin Schnorf
crwdns2935283:010/03/16crwdne2935283:0
252 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-5, Forte Fall 2016 crwdns2935289:0Cal Poly, Team 18-5, Forte Fall 2016crwdne2935289:0
CPSU-FORTE-F16S18G5
crwdns2935297:036crwdne2935297:0
where can i buy new screen????
eibrims - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Yeah, I want to know where I can buy a screen for my hp stream 7.
Rider Sd - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can i buy a new screen for the stream 7 please??
migueajr - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same question but no answer !
Where can anyone find replacement screen online ??
Ahmed Saleh - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
We're I can buy the replacement screen?
Raymond Borrero - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 115
crwdns2942667:0crwdne2942667:0 4,888
