HP Stream 13-c110nr Touchpad Assembly Replacement
  1. HP Stream 13-c110nr Touchpad Assembly Replacement, Keyboard Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device upside down with the back facing towards you.
  3. HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  6. HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  7. HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the Touchpad cable.
  8. HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the Keyboard Cable.
  9. HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the Power connector cable.
  10. HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Keyboard/Top Cover from the device.
  11. HP Stream 13-c110nr Touchpad Assembly Replacement, Touchpad Assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 13-c110nr Touchpad Assembly Replacement, Touchpad Assembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the Top Cover/Keyboard assembly face down with the front towards you.
  12. HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the TouchPad cable.
  13. HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two (2) Phillips P0 PM2.5x3.0 mm screws from Touchpad assembly.
    • Place two (2) screws on magnetic mat for reassembly.
  14. HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic pick to pry up the black TouchPad cover from the blue top cover.
    • The TouchPad cover is molded to the Top Cover/Keyboard. Slight pressure must be maintained to release the cover.
    • A popping noise may be heard when prying the touchpad cover off of the top cover.
  15. HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 13-c110nr Touchpad Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Touchpad assembly from the device.
Stacey Deel
crwdns2935283:001/31/19crwdne2935283:0
1,147 crwdns2915208:0crwdne2915208:0
Appalachian State University, Team S1-G2, Menagarishvili Spring 2019 crwdns2935289:0Appalachian State University, Team S1-G2, Menagarishvili Spring 2019crwdne2935289:0
APSU-MENAGARISHVILI-S19S1G2
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 214
