HP Stream 13-c110nr Battery Assembly Replacement
    1. HP Stream 13-c110nr Battery Assembly Replacement, Keyboard Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Close the device.
      • Remove AC adapter plug from electrical outlet.
      • Remove AC adapter from device.
      • Turn the device off.
      • Unplug all external devices from device.
      • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
    2. HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the device upside down with the back facing towards you.
    3. HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a pick to remove the two (2) large computer feet along the back edge of the device.
      • Use a pick to remove the two (2) small computer feet.
      • Use a pick to remove the one (1) screw cover.
      • Place rubber computer feet in safe place for reassembly.
    4. HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      Magnetic Project Mat
      $19.95
      • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
      • Place the thirteen (13) screws on magnetic mat for reassembly.
    5. HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the device over with the front facing towards you.
      • Open the device as shown.
    6. HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
      • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
    7. HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the Touchpad cable.
    8. HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the Keyboard Cable.
    9. HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the Power connector cable.
    10. HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the Keyboard/Top Cover from the device.
    1. HP Stream 13-c110nr Battery Assembly Replacement, Battery Assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 13-c110nr Battery Assembly Replacement, Battery Assembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a pick to detach the Battery assembly cable.
    2. HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove eight (8) Phillips P0 PM2.0x3.0 mm screws from Battery assembly.
      • Place eight (8) screws on magnetic mat for reassembly.
    3. HP Stream 13-c110nr Battery Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove Battery Assembly from device.
Stacey Deel
crwdns2935283:001/31/19crwdne2935283:0
1.159 crwdns2915208:0crwdne2915208:0
Appalachian State University, Team S1-G2, Menagarishvili Spring 2019 crwdns2935289:0Appalachian State University, Team S1-G2, Menagarishvili Spring 2019crwdne2935289:0
APSU-MENAGARISHVILI-S19S1G2
crwdns2935297:099crwdne2935297:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 1,293
