HP Stream 13-c010nr Display Replacement
  1. HP Stream 13-c010nr Display Replacement, laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
  2. HP Stream 13-c010nr Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 13-c010nr Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
  3. HP Stream 13-c010nr Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 13-c010nr Display Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
  4. HP Stream 13-c010nr Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
  5. HP Stream 13-c010nr Display Replacement, Display: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw covers from the bottom corner edges of the screen.
  6. HP Stream 13-c010nr Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 13-c010nr Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 5mm Phillips #0 screws from the screen bezel.
  7. HP Stream 13-c010nr Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 13-c010nr Display Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge the plastic opening tool between the frame of the screen and the casing of the laptop.
    • Pry upwards on the plastic opening tool to separate the bezel from the display.
  8. HP Stream 13-c010nr Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3mm Phillips #0 screws from the screen.
  9. HP Stream 13-c010nr Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to flip up the retaining flap on the screen ribbon cable ZIF socket.
    • Pull the ribbon cable out of the ZIF socket.
    • Remove the screen.
Keegan Lapham
crwdns2935283:002/22/18crwdne2935283:0
759 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G3, Cagle Spring 2018 crwdns2935289:0USF Tampa, Team S1-G3, Cagle Spring 2018crwdne2935289:0
USFT-CAGLE-S18S1G3
crwdns2942667:0crwdne2942667:0 832
