HP Stream 11-d010nr Daughterboard Replacement
  1. HP Stream 11-d010nr Daughterboard Replacement, Pry out the inserts: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 11-d010nr Daughterboard Replacement, Pry out the inserts: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
    • Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
  2. HP Stream 11-d010nr Daughterboard Replacement, Unscrew the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
    • Keep the screws in a safe place for reassembly.
  3. HP Stream 11-d010nr Daughterboard Replacement, Pry the keyboard casing up: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 11-d010nr Daughterboard Replacement, Pry the keyboard casing up: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
  4. HP Stream 11-d010nr Daughterboard Replacement, Identify the connectors: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
    • Lift the keyboard with extreme care to avoid damaging the delicate ribbon cables. Applying excessive force can easily tear or break them easily.
  5. HP Stream 11-d010nr Daughterboard Replacement, Disconnect the cables: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 11-d010nr Daughterboard Replacement, Disconnect the cables: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 11-d010nr Daughterboard Replacement, Disconnect the cables: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
    • Carefully disconnect the three ribbon cables.
  6. HP Stream 11-d010nr Daughterboard Replacement, Lift the keyboard out: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the keyboard out of the laptop to fully detach it from the device.
    • While handling, avoid damaging any remaining components.
  7. HP Stream 11-d010nr Daughterboard Replacement, Daughterboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the ribbon out of the daughterboard.
  8. HP Stream 11-d010nr Daughterboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3mm screws.
  9. HP Stream 11-d010nr Daughterboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the daughterboard.
Riley Patrick Geoghegan
crwdns2935283:010/03/22crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team 1-10, Eggleston Fall 2022 crwdns2935289:0The Citadel Military College of South Carolina, Team 1-10, Eggleston Fall 2022crwdne2935289:0
CMCSC-EGGLESTON-F22S1G10
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 233
