If your HP Stream 11-d010nr laptop is showing signs of a faulty battery, such as not holding a charge or not turning on at all, its battery may need to be replaced. This guide will show you the steps necessary to do so.
Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
Carefully disconnect the three ribbon cables.
Gently lift the keyboard out of the laptop to fully detach it from the device.
Remove any tape holding the battery connector in place.
Using your fingers, carefully unplug the battery.
Remove the four 3mm #000 Phillips screws holding the battery in place.
Carefully lift the battery out of the laptop.
HP lists the screws on the back cover as size pm1.9x5.6. What is wrong with HP that they would use such an odd size? I tried 2x6mm and they seem to work fine.
Greg Worrel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Me podrias ayudar con el numero de serie del boton de encendido
sam Carrizales - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
O donde lo puedo conseguir
