HP Stream 11-d008TU Battery Connector Unplugging
  1. HP Stream 11-d008TU Battery Connector Unplugging, Rubber Feet Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 11-d008TU Battery Connector Unplugging, Rubber Feet Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 11-d008TU Battery Connector Unplugging, Rubber Feet Removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a prying tool to pry the 2 rubber feet off closest to the hinge of the device
    • Repeat this process for the other side of the device
    • The bottom rubber feet do not have hidden screws underneath them, and as such, they are unnecessary to remove
  2. HP Stream 11-d008TU Battery Connector Unplugging, Screw removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Stream 11-d008TU Battery Connector Unplugging, Screw removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 11x 5mm Phillips PH-0 screws (circled)
  3. HP Stream 11-d008TU Battery Connector Unplugging, Keyboard Unclipping: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard Unclipping: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard Unclipping: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your finger to pry the outer blue shell over the keyboard
    • Continue this process around the edges of the device
    • You may have to use a prying tool to pry the harder edges such as around the I/O ports
    • Do not lift the keyboard once all the clips are undone, as there are still various cables connected
  4. HP Stream 11-d008TU Battery Connector Unplugging, Keyboard removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard removal: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the power button connector by peeling back the protective tape, using your fingernail to flip the white retaining clip back, and pulling the ribbon cable out
    • Disconnect the touchpad connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Disconnect the keyboard connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Your keyboard assembly is now safe to remove
  5. HP Stream 11-d008TU Battery Connector Unplugging, Battery Connector: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Stream 11-d008TU Battery Connector Unplugging, Battery Connector: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Stream 11-d008TU Battery Connector Unplugging, Battery Connector: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the white plastic connector on the motherboard
    • Peel back the black tape holding the cable's wires in place
    • Pull the white connector out by puling the white plastic away from the connector
    • Do not grab the connector by the wires
Joel Taylor
crwdns2935283:003/07/20crwdne2935283:0
1,346 crwdns2915208:0crwdne2915208:0
Australia crwdns2935289:0Australiacrwdne2935289:0
Community
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 168
