HP Sprocket 2-in-1 USB Port Replacement
  1. HP Sprocket 2-in-1 USB Port Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Sprocket 2-in-1 USB Port Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover and any printer paper inside the device.
  2. HP Sprocket 2-in-1 USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Sprocket 2-in-1 USB Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Jimmy, slowly pry open the outer edge of the remaining white plastic on the back.
    • Remove the plastic from the device once it lifts out freely.
  3. HP Sprocket 2-in-1 USB Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Sprocket 2-in-1 USB Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Sprocket 2-in-1 USB Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two 2.5mm JIS #00 located on the small circuit board in view.
    • Use the Jimmy to remove the board after the screws have been removed.
    • Be careful not to crease or damage the ribbon cable.
  4. HP Sprocket 2-in-1 USB Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Sprocket 2-in-1 USB Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Sprocket 2-in-1 USB Port Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two 2.5mm JIS #00 screws from the translucent plastic bracket.
    • One will be located beneath the ribbon cable.
    • Remove the translucent plastic bracket by hand.
  5. HP Sprocket 2-in-1 USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Sprocket 2-in-1 USB Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four 2.5mm JIS #00 screws from the beige casing.
  6. HP Sprocket 2-in-1 USB Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Sprocket 2-in-1 USB Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Sprocket 2-in-1 USB Port Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the iFixit opening tool to slowly work between the white and beige casing around the device.
    • Flip the device over and seperate the white casing from the rest of the device.
    • Be careful not to break the plastic while removing the case.
    • Gently remove the white casing as there is a ribbon cable connecting the two pieces.
  7. HP Sprocket 2-in-1 USB Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the ribbon cable that connects the flash to the outer casing.
  8. HP Sprocket 2-in-1 USB Port Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Sprocket 2-in-1 USB Port Replacement, Battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a JIS #00 screwdriver to remove a single black screw near the viewfinder.
    • Remove a single silver 2.5mm JIS #00 screw near the USB port of the device.
    • Carefully remove the metal bracket.
  9. HP Sprocket 2-in-1 USB Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Work the battery free from the device with the iFixit opening tool.
    • Carefully disconnect the battery from the board.
  10. HP Sprocket 2-in-1 USB Port Replacement, USB Port: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Sprocket 2-in-1 USB Port Replacement, USB Port: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the metal tweezers, remove the ribbon from the motherboard.
    • Remove two 2.5mm Japanese Industrial Standard (J00) screws on each side of the USB port.
  11. HP Sprocket 2-in-1 USB Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SD Port with metal tweezers.
    • You can now replace the SD port with a new one.
Paulo Warren
crwdns2935283:002/05/19crwdne2935283:0
458 crwdns2915208:0crwdne2915208:0
University of Michigan, Team S1-G4, Li Winter 2019 crwdns2935289:0University of Michigan, Team S1-G4, Li Winter 2019crwdne2935289:0
UMIC-LI-W19S1G4
crwdns2942667:0crwdne2942667:0 416
