HP Split x2 Screen Replacement
  1. HP Split x2 Screen Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Opening the device voids the manufacturer warranty.
    • Power down the HP Split x2 before beginning the repair
    • Separate the tablet from the keyboard by pushing the slider to the left and lifting the tablet from the keyboard.
  2. HP Split x2 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Split x2 Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Split x2 Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four white caps on the bottom edge of the tablet.
    • Use a tweezer to grasp white caps.
    • The white caps are easily lost. Store them in a secure place.
  3. HP Split x2 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the four 3mm screws.
  4. HP Split x2 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split x2 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry the tabs on the top, left and right sides of the tablet.
    • Only the top and sides have tabs. Remove all tabs before lifting screen.
  5. HP Split x2 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split x2 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the cover and the screen.
    • Gently lift the screen out of the cover.
  6. HP Split x2 Screen Replacement, Screen: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split x2 Screen Replacement, Screen: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a J0 screwdriver to remove the ten 4mm Phillips screws.
  7. HP Split x2 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split x2 Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back the large black tape.
    • Remove the 4mm Phillips screw.
  8. HP Split x2 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Split x2 Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Split x2 Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove three 2 mm zero insertion force (ZIF) connectors. Lift the black tab in front and then remove the ribbon from the rear.
    • Remove two larger zero insertion force (ZIF) connectors. Lift the black tab in front and then remove the ribbon from the rear.
  9. HP Split x2 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Split x2 Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Split x2 Screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The last attachment to the screen is the bronze colored display cable connector.
    • Use a pair of tweezers to lift the metal bar and swing it to the other side on top of the cable.
    • Pull in the direction of the cable to remove the connector.
  10. HP Split x2 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Glue is holding the device together along the edges. The glue is can be very strong. A heat gun may be required to loosen the glue for removal of the digitizer to prevent damage to the screen.
    • Apply pressure to to the sides of the tablet.
    • Separate the digitizer from the the body of the tablet.
    Glue was not very weak for me. I broke my screen trying to remove the digitizer. Recommend using a heat gun to weaken glue that is used to hold digitizer in place.
    rogershomework - crwdns2934203:0crwdne2934203:0
  11. HP Split x2 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split x2 Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Glue is holding the screen on at the four corners.
    • Lift the screen up, breaking any adhesion forced by the glue.
    • Replace the old screen with a new one.
crwdns2935229:011crwdne2935229:0
Ricky Huitema
crwdns2935283:009/24/15crwdne2935283:0
464 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 22-5, Rauch Fall 2015 crwdns2935289:0Texas Tech, Team 22-5, Rauch Fall 2015crwdne2935289:0
TTU-RAUCH-F15S22G5
crwdns2947412:05crwdne2947412:0
This is not helpful because the one I am working on has no screws.
Matt Brown - crwdns2934203:0crwdne2934203:0
I also have a Split x2 with no screws
dbmacaulay -
I want change my screen because My screen is broken but I do not know , where I can buy my screen
Nohora Chitiva - crwdns2934203:0crwdne2934203:0
ebay or amazon
Andrei Isari -
Is HP Touch Screen Digitizer Glass for HP Split X2 The same as the screen being replaced here?? I need to know
Nwatu Chineme Edger - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 13,417
