HP Split x2 13-g210dx Speakers Replacement
  1. HP Split x2 13-g210dx Speakers Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx Speakers Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery away from the device.
  5. HP Split x2 13-g210dx Speakers Replacement, Docking Port: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4-mm Phillips #0 screws.
  6. HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the clips from the docking port board with a sturdy pair of tweezers.
  7. HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two ribbons labeled "Dock" at the top of the docking port board using tweezers or a sturdy plastic opening tool.
  8. HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the docking port away from the device.
  9. HP Split x2 13-g210dx Speakers Replacement, SD Port: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  10. HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the yellow ribbon labeled "SD" in the left corner of the SD port board using tweezers or a sturdy plastic opening tool.
  11. HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the SD port away from the device.
  12. HP Split x2 13-g210dx Speakers Replacement, Audio Port: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  13. HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two purple ribbons labeled "Audio" at the top of the audio port board using tweezers or a sturdy plastic opening tool.
  14. HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the white clip at the top right corner of the audio port board using tweezers.
  15. HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the Audio port away from the device.
  16. HP Split x2 13-g210dx Speakers Replacement, Speakers: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split x2 13-g210dx Speakers Replacement, Speakers: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4-mm Phillips #0 screw.
    • Lift the left speaker away from the device.
  17. HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4-mm Phillips #0 screw from the same location as found on the left speaker.
    • Lift the right speaker away from the device.
  18. HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Split x2 13-g210dx Speakers Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the bonded white and black speaker wires running along the bottom of the control board from the fastening clips.
    • Lift the speaker assembly away from the device.
Darian Devries
crwdns2935283:002/25/19crwdne2935283:0
507 crwdns2915208:0crwdne2915208:0
Purdue University Northwest, Team S4-G1, Hingst Spring 2019 crwdns2935289:0Purdue University Northwest, Team S4-G1, Hingst Spring 2019crwdne2935289:0
PNW-HINGST-S19S4G1
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 340
