HP Split x2 13-g210dx Battery Replacement
  1. HP Split x2 13-g210dx Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split x2 13-g210dx Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split x2 13-g210dx Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery away from the device.
crwdns2935229:05crwdne2935229:0
Darian Devries
crwdns2935283:002/25/19crwdne2935283:0
507 crwdns2915208:0crwdne2915208:0
Purdue University Northwest, Team S4-G1, Hingst Spring 2019 crwdns2935289:0Purdue University Northwest, Team S4-G1, Hingst Spring 2019crwdne2935289:0
PNW-HINGST-S19S4G1
crwdns2942667:0crwdne2942667:0 2,373
