HP Split 13-r010dx Screen Replacement
  1. HP Split 13-r010dx Screen Replacement, Front and Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split 13-r010dx Screen Replacement, Front and Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the four screws at the bottom of the device. (Note that the keyboard attachment is missing from this device.)
    • Use a Philips head #0 screwdriver to remove each of the screws (Size: 4mm)
  2. HP Split 13-r010dx Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split 13-r010dx Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently wedge the plastic opening tool in between where the display and back panel meet.
    • Slowly and gently apply force to the plastic opening tool in a downwards motion to loosen the front panel from the back panel.
    • Rotate the device so that the side is facing up and repeat the previous step for the sides.
    • Do NOT attempt to wedge the plastic opening tool on the bottom . Once the sides and top are loose you are ready to continue to the next step.
  3. HP Split 13-r010dx Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently and slowly pull the front and back panel away from each other (in opposite directions). ( Pulling them apart will not separate the two panels)
    • Only separate the panels by a few inches from each other so that there is room to separate the front and back panel in the next step. Proceed to the next step.
  4. HP Split 13-r010dx Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the back panel firmly and pull the front panel upwards to completely separate the front panel from the back panel.
    • The device is now ready to be repaired or replacements installed.
  5. HP Split 13-r010dx Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Split 13-r010dx Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Split 13-r010dx Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the PH1 screwdriver to remove eleven 4mm Phillips screws.
  6. HP Split 13-r010dx Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Split 13-r010dx Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 2mm zero insertion force connectors. Slide aside the white wires to properly unscrew.
  7. HP Split 13-r010dx Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Split 13-r010dx Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Split 13-r010dx Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to pull up the yellow colored display cable connector.
    • Pull it to the direction of the cable.
  8. HP Split 13-r010dx Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Glue is attached at the edges. Apply force to the sides of the tablet. Separate the digitizer from the body of the tablet.
    • Replace the old screen with a new one.
    • If your screen is broken or damaged, use caution when pulling the screen from the tablet to avoid self harm.
bushraishaq
crwdns2935283:009/25/17crwdne2935283:0
327 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S2-G1, Thompson Fall 2017 crwdns2935289:0University of North Texas, Team S2-G1, Thompson Fall 2017crwdne2935289:0
UNT-THOMPSON-F17S2G1
Hello… How to know if it is the digitizer or the screen that is broken? .. thanks
Martin Sala - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 712
