HP Spectre x360 15-bl012dx SSD Replacement
  1. HP Spectre x360 15-bl012dx SSD Replacement, Battery Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 15-bl012dx SSD Replacement, Battery Replacement: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off the device before beginning disassembly.
    • Place the computer so that the back panel is facing up. Begin by removing the two visible Torx T5 9 mm screws near the hinges.
    • Next, remove the four visible Torx T5 3 mm on the sides.
    • Keep track of all screws.
  2. HP Spectre x360 15-bl012dx SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 15-bl012dx SSD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 15-bl012dx SSD Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Please note the upper two feet are already removed. The device was given to us this way.
    • Remove the two upper feet using an opening tool or spudger if they are still in place. The upper feet are closer to the hinges for the screen.
    • Remove the two 8 mm Phillips #1 screws under the feet.
    • These are the final screws to remove from the back panel. In total, you should remove eight screws between Steps 1 and 2.
  3. HP Spectre x360 15-bl012dx SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry the back panel off of the laptop. Work your way around the perimeter of the device to loosen the connection.
    • Take the back panel off of the laptop.
  4. HP Spectre x360 15-bl012dx SSD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove six 4 mm screws securing the battery.
  5. HP Spectre x360 15-bl012dx SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 15-bl012dx SSD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 15-bl012dx SSD Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the battery connector located on the motherboard.
    • Remove the battery from the laptop.
  6. HP Spectre x360 15-bl012dx SSD Replacement, Solid State Drive (SSD): crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 15-bl012dx SSD Replacement, Solid State Drive (SSD): crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 15-bl012dx SSD Replacement, Solid State Drive (SSD): crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using minimal force, lift the locking bars on the USB board ZIF connector using a plastic opening tool or fingernail and pull out the ribbon cable.
  7. HP Spectre x360 15-bl012dx SSD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, remove the USB ribbon cable from the motherboard above the fan.
  8. HP Spectre x360 15-bl012dx SSD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 15-bl012dx SSD Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3 mm Phillips #1 screw that secures the solid state drive to the board.
    • Please note this laptop was not supplied with an SSD, so this is not the same SSD you will find in your device.
  9. HP Spectre x360 15-bl012dx SSD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the SSD card out of the connection at a 45 degree angle so that the SSD teeth are not bent.
Cade Caldwell
crwdns2935283:002/22/22crwdne2935283:0
202 crwdns2915208:0crwdne2915208:0
Clemson, Team 1-1, Hunter Spring 2022 crwdns2935289:0Clemson, Team 1-1, Hunter Spring 2022crwdne2935289:0
CLEM-HUNTER-S22S1G1
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 2,838
