HP Spectre x360 15-bl012dx Battery Replacement
  1. HP Spectre x360 15-bl012dx Battery Replacement, Battery Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 15-bl012dx Battery Replacement, Battery Replacement: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off the device before beginning disassembly.
    • Place the computer so that the back panel is facing up. Begin by removing the two visible Torx T5 9 mm screws near the hinges.
    • Next, remove the four visible Torx T5 3 mm on the sides.
    • Keep track of all screws.
  2. HP Spectre x360 15-bl012dx Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 15-bl012dx Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 15-bl012dx Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Please note the upper two feet are already removed. The device was given to us this way.
    • Remove the two upper feet using an opening tool or spudger if they are still in place. The upper feet are closer to the hinges for the screen.
    • Remove the two 8 mm Phillips #1 screws under the feet.
    • These are the final screws to remove from the back panel. In total, you should remove eight screws between Steps 1 and 2.
  3. HP Spectre x360 15-bl012dx Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry the back panel off of the laptop. Work your way around the perimeter of the device to loosen the connection.
    • Take the back panel off of the laptop.
  4. HP Spectre x360 15-bl012dx Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove six 4 mm screws securing the battery.
  5. HP Spectre x360 15-bl012dx Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 15-bl012dx Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 15-bl012dx Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the battery connector located on the motherboard.
    • Remove the battery from the laptop.
Peyton Stewart
crwdns2935283:002/22/22crwdne2935283:0
300 crwdns2915208:0crwdne2915208:0
Clemson, Team 1-1, Hunter Spring 2022 crwdns2935289:0Clemson, Team 1-1, Hunter Spring 2022crwdne2935289:0
CLEM-HUNTER-S22S1G1
crwdns2947412:07crwdne2947412:0
Great writeup. Any idea where I could get an OEM or OEM-quality replacement battery?
Ben - crwdns2934203:0crwdne2934203:0
Excellent guidance, many thanks!
Brenda Mallinson - crwdns2934203:0crwdne2934203:0
Thanks for the guide! Figured there were screws under the rear feet but this confirmed it and prevented me from doing something silly.
Nick Di Vona - crwdns2934203:0crwdne2934203:0
Where are you guys finding replacement batteries from? I don't want to go through the process of buying and returning crappy batteries
Kisan Patel - crwdns2934203:0crwdne2934203:0
Instructions worked perfectly for my Spectre x360 15 using the SU06XL battery purchased from iFixit. Battery behaves well but on power-up a warning appears saying a non-HP battery has been detected and this is a potential health and safety hazard. BIOS update did not cure the problem. Has anyone a solution to this?
pnwclam - crwdns2934203:0crwdne2934203:0
I purchased a YB06XL Battery Replacement for HP Spectre X360 from Amazon and its working great.
robert benoit - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,998
