HP Spectre x360 13t-4000 SD Card Reader Replacement
  1. HP Spectre x360 13t-4000 SD Card Reader Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13t-4000 SD Card Reader Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 SD Card Reader Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13t-4000 SD Card Reader Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 SD Card Reader Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13t-4000 SD Card Reader Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13t-4000 SD Card Reader Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 SD Card Reader Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13t-4000 SD Card Reader Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13t-4000 SD Card Reader Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
    • With the screws removed, disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to remove the wires.
  5. HP Spectre x360 13t-4000 SD Card Reader Replacement, SD Card Reader: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13t-4000 SD Card Reader Replacement, SD Card Reader: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2 mm long Phillips #000 head screw on the SD Card Reader.
    • Using a plastic spudger, release the pressure connector marked with the green rectangle by gently prying up from below.
    • Once the pressure connector is undone, the white ribbon cable connected to the SD Card Reader will pull out with no resistance.
    • With the ribbon cable disconnected and the screw out, the SD Card Reader will be free to remove and replace.
    • When replacing the SD Card Reader, ensure the ribbon cable is firmly secured in the pressure connector, with the metal contact points facing down towards the motherboard.
Brandon Carvalho
crwdns2935283:003/21/19crwdne2935283:0
566 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G4, Simcock Spring 2019 crwdns2935289:0UMass Dartmouth, Team S2-G4, Simcock Spring 2019crwdne2935289:0
UMASSD-SIMCOCK-S19S2G4
crwdns2942667:0crwdne2942667:0 802
