HP Spectre x360 13t-4000 Motherboard Replacement
  1. HP Spectre x360 13t-4000 Motherboard Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13t-4000 Motherboard Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13t-4000 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13t-4000 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13t-4000 Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13t-4000 Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13t-4000 Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
    • With the screws removed, disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to remove the wires.
  5. HP Spectre x360 13t-4000 Motherboard Replacement, Heatsink and Fan Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13t-4000 Motherboard Replacement, Heatsink and Fan Assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13t-4000 Motherboard Replacement, Heatsink and Fan Assembly: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 Screwdriver to remove the four circled 3 mm screws.
    • Use the same screwdriver to remove the circled 4 mm screw.
  6. HP Spectre x360 13t-4000 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13t-4000 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove black adhesive tape and metal shielding.
  7. HP Spectre x360 13t-4000 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13t-4000 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the last 4 mm screw under the black tape.
    • Unplug the cable next to the fan.
  8. HP Spectre x360 13t-4000 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13t-4000 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove heatsink and fan assembly.
    • Reapply fresh thermal paste to the CPU before placing a heatsink back in the device.
  9. HP Spectre x360 13t-4000 Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 Screwdriver to remove the 2.6 mm and 2.7 mm screws.
    • Strip wire present in the motherboard must also be removed
  10. HP Spectre x360 13t-4000 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13t-4000 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13t-4000 Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • For the strip wires, push the white tab seen in the photo up gently and slowly pull the strip wire.
    • The normal wires can be removed by holding the sides of the connector and gently pulling away.
    • Finally, the screws can be removed.
  11. HP Spectre x360 13t-4000 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You may now pull the motherboard off the computer to access it.
Justin Dages
crwdns2935283:003/28/23crwdne2935283:0
385 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-5, Harley Spring 2023 crwdns2935289:0IUPUI, Team 2-5, Harley Spring 2023crwdne2935289:0
IUPUI-HARLEY-S23S2G5
crwdns2942667:0crwdne2942667:0 362
