HP Spectre x360 13-aw0xxx Charging Port Replacement
  1. HP Spectre x360 13-aw0xxx Charging Port Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use two opening tools, one on either side of the battery plug, to slowly pull the plug straight out of its port.
    • Alternatively, use your fingernails.
  2. HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws securing the battery.
  3. HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the edge of the battery with an opening tool.
    • Lift the battery up and out.
  4. HP Spectre x360 13-aw0xxx Charging Port Replacement, Fan Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement, Fan Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement, Fan Assembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the black film around the fans.
  5. HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two Wi-Fi card antenna wires using a small pry tool.
  6. HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 3 mm Phillips #00 screws securing the fan assembly.
  7. HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the two fan cables using a small pry tool.
    • Be sure not to rip the wires, as they are fragile. It may help to slightly pry on the fans while disconnecting the wires, so the pry bar has enough room.
  8. HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to gently lift the edge of the fan assembly.
    • Lift the fan assembly up and out.
  9. HP Spectre x360 13-aw0xxx Charging Port Replacement, Charging Port: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement, Charging Port: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 3 mm screws securing the motherboard using a Phillips #00 screwdriver.
  10. HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the display cable from the motherboard using a small pry tool.
  11. HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the smaller flip screen sensor cable from the motherboard.
  12. HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the ZIF connector lock bars up to release the ribbon cables.
    • Remove the ribbon cables.
  13. HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start removing the I/O board by removing the piece in the upper right corner (opposite the charging port side).
    • Use a small opening tool to remove up the I/O board from the body.
  14. HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-aw0xxx Charging Port Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a small pry tool lift up on the larger portion of the motherboard to remove it from the body of the laptop.
    • The motherboard will be free from the laptop body and the new charging port and motherboard can be inserted.
Jacob Wallace
crwdns2935283:002/14/23crwdne2935283:0
139 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-6, Virtue Spring 2023 crwdns2935289:0Western Carolina University, Team 1-6, Virtue Spring 2023crwdne2935289:0
WCU-VIRTUE-S23S1G6
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 1,952
