HP Spectre x360 13-aw0xxx Battery Replacement
  1. HP Spectre x360 13-aw0xxx Battery Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-aw0xxx Battery Replacement, Lower Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the following screws securing the lower case:
    • Four Phillips #00 6 mm screws
    • Two T5 Torx 3 mm screws
  2. HP Spectre x360 13-aw0xxx Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert an opening tool in the seam between the lower case and chassis.
    • Pry around the perimeter until the lower case fully releases.
    • Remove the lower case.
  3. HP Spectre x360 13-aw0xxx Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-aw0xxx Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use two opening tools, one on either side of the battery plug, to slowly pull the plug straight out of its port.
    • Alternatively, use your fingernails.
  4. HP Spectre x360 13-aw0xxx Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-aw0xxx Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws securing the battery.
  5. HP Spectre x360 13-aw0xxx Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-aw0xxx Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the edge of the battery with an opening tool.
    • Lift the battery up and out.
Thomas Hayslett
crwdns2935283:002/14/23crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-6, Virtue Spring 2023 crwdns2935289:0Western Carolina University, Team 1-6, Virtue Spring 2023crwdne2935289:0
WCU-VIRTUE-S23S1G6
I just replaced the battery using the ifixit battery mentioned here. Everything was working fine until I realized that my laptop shut down, the battery ran out in about 1 hour and the BIOS screen said that a non-hp battery has been detected.
Siddharth Preetham - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 96
crwdns2942667:0crwdne2942667:0 2,910
