HP Spectre x360 13-ac023dx Motherboard Replacement
  1. HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
    Was eine dämliche Konstruktion, Schrauben unter Füßen zu verstecken!!!
    Dirk S. - crwdns2934203:0crwdne2934203:0
  3. HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
    Need to provide a direction in step #1 about removing the rubber pads and accessing the two screws at the bottom.
    David McCurry - crwdns2934203:0crwdne2934203:0
    Second that. What's the best way to remove the feet?
    Oskar Petersons - crwdns2934203:0crwdne2934203:0
  4. HP Spectre x360 13-ac023dx Motherboard Replacement, Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the Cooling Fan in the device.
  5. HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #000 screwdriver to remove the 3mm screws holding the fan in place.
    • Remove the wires connecting to the motherboard, using the iFixit opening tool.
    • The iFixit Opening Tool is not required, but recommended
  6. HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Cooling Fan.
  7. HP Spectre x360 13-ac023dx Motherboard Replacement, WiFi Card: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the WiFi card in the top left of the motherboard.
  8. HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
  9. HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screw is removed, hold the WiFi card by it's sides and raise it up whiling sliding it out from the slot.
  10. HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the Wifi card, place the card within a static dissipative bag.
  11. HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the replacement Wifi card by the edges and remove it out of the static-dissipative bag.
  12. HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the notches on the Wifi card with the keys on the Wifi card slot.
    • Hold the card by the edges and slide the Wifi card into the Wifi Card slot.
  13. HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #000 screwdriver to attach the screw holding the Wifi card in place.
  14. HP Spectre x360 13-ac023dx Motherboard Replacement, Motherboard: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure that all other components which were previously removed are not longer attached.
  15. HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the wires which connect the motherboard to the rest of the components.
    • The black and red wire can be removed by pulling the wire upwards.
  16. HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #000 screwdriver to remove the three 3.5 mm screws which keep the motherboard in place.
  17. HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 13-ac023dx Motherboard Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift and remove the motherboard.
Jonathan
crwdns2935283:010/21/19crwdne2935283:0
498 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 crwdns2935289:0UMass Dartmouth, Team S1-G6, Botvin Fall 2019crwdne2935289:0
UMASSD-BOTVIN-F19S1G6
crwdns2935297:011crwdne2935297:0
Can I get ho spectre x360 motherboard to buy from your end?
Immanuel - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 3,966
