If your HP Spectre x360 13-ac023dx laptop will not boot up after troubleshooting possibles errors, use this motherboard replacement guide.
Flip the laptop over so the model sticker faces the ceiling.
Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
Then, carefully lift the battery off with the iFixit opening tool.
Locate the Cooling Fan in the device.
Use the Phillips #000 screwdriver to remove the 3mm screws holding the fan in place.
Remove the wires connecting to the motherboard, using the iFixit opening tool.
Locate the WiFi card in the top left of the motherboard.
Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
Once the screw is removed, hold the WiFi card by it's sides and raise it up whiling sliding it out from the slot.
After removing the Wifi card, place the card within a static dissipative bag.
Hold the replacement Wifi card by the edges and remove it out of the static-dissipative bag.
Align the notches on the Wifi card with the keys on the Wifi card slot.
Hold the card by the edges and slide the Wifi card into the Wifi Card slot.
Use the Phillips #000 screwdriver to attach the screw holding the Wifi card in place.
Ensure that all other components which were previously removed are not longer attached.
Disconnect the wires which connect the motherboard to the rest of the components.
Use the Phillips #000 screwdriver to remove the three 3.5 mm screws which keep the motherboard in place.
Carefully lift and remove the motherboard.
Can I get ho spectre x360 motherboard to buy from your end?
