HP Spectre x2 12-a002dx Battery Replacement
  1. HP Spectre x2 12-a002dx Battery Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the device is powered off and the kick stand is retracted.
    • The HP Spectre should be placed on a flat surface with the keyboard detached.
  2. HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the screen, there is an entire system of clips which need to be undone as well as 4 Phillips M1.5x2.7 screws.
    • The screws should be removed using a Phillips #000 screwdriver. There is a sticker where the laptop attaches to the keyboard.
    • Heat the sticker (if needed) and use fine point tweezers to grip the sticker and remove it.
    Could you please some image of the screws and the tool you used?
    fabio - crwdns2934203:0crwdne2934203:0
    Podrían subir el procedimiento para despegar los clip, ? al parecer viene pegada la pantalla a la carcasa, en ese caso se usaría la pistola de calor o estoy mal ? Al guíen que me guié por favor, agradezco de antemano
    sergio villanueva - crwdns2934203:0crwdne2934203:0
  3. HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tools or insert a spudger to begin unclipping the system.
    • Pry the screen off once all the clips have been unclipped.
    • The screen may shatter if not already shattered (beware of flying glass).
    • This screen will break. There is double tape underneath the frame, which is not listed in here.
  4. HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the connecting cable of the screen and battery. Use a spudger to reveal the adhesive strip and carefully peel it off.
    • Insert a spudger to the other end and release the ZIF connectors. Detach the cable.
    • While a metal spudger is pictured, use a black nylon spudger instead because it is ESD safe.
  5. HP Spectre x2 12-a002dx Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery for this device is under the screen and takes up most of the space.
  6. HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the wire gently towards the connector.
    • Then, disconnect the wire and remove it from the device.
  7. HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six Phillips M2.0×3.5 screws connecting the battery to the device using the JIS 00 screwdriver.
    • Make sure to keep the screws in a safe place. You will need to use them to secure the replacement battery back in place.
  8. HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to push the battery connector out of its socket.
    • It helps to "walk" the connector out by pressing first on one side, then the other.
  9. HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the side of the battery that isn't glued down with adhesive
    • Use the spatula to gently scrape away the adhesive while applying a gentle upward pressure to help break the adhesive bonds.
    • A metal spudger was used again as pictured, but the black nylon spudger would be more appropriate to use.
  10. HP Spectre x2 12-a002dx Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally remove the old battery.
Talha Bin Amir
crwdns2935283:010/23/17crwdne2935283:0
684 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S10-G6, Thompson Fall 2017 crwdns2935289:0USF Tampa, Team S10-G6, Thompson Fall 2017crwdne2935289:0
USFT-THOMPSON-F17S10G6
crwdns2947412:017crwdne2947412:0
Awesome, thanks a lot! My old Spectre’s battery now only supports less than 2 hours, wish I could replace it with a new one.
Claud Monet - crwdns2934203:0crwdne2934203:0
Clear - Complete - Accurate instructions led me through the successful replacement. glad I found this. Good Job.
Mayne Mihacsi - crwdns2934203:0crwdne2934203:0
Did the screen crack for you
Tiffany -
Where can the replacement battery be purchased?
Jay Mac - crwdns2934203:0crwdne2934203:0
Did the screen crack for anyone?
Tiffany - crwdns2934203:0crwdne2934203:0
Trying to find the best way for this because they told me that if the screen cracked would cost me 600 to fix, might as well buy a new computer for that price
I cracked my screen during step 3. There are adhesive strips at the bottom of the screen and you do not want to flex the screen to pull it away from the strips. Just take your time and don’t put too much stress on your screen.
Also, I skipped steps 4-6. The battery was there and no need to remove that cable. Good Luck
Dax Oster - crwdns2934203:0crwdne2934203:0
@ Jay Mac, I purchased a deadstock HP battery off ebay for $26 shipped. I was skeptical, but it works and I get 8 hours of screen time out of it.
Hello, can you recall where did you buy battery from?
thanks
Dang Truong -
Hi, Yes the screen did crack for me.. i order from the supplier oversea, $145 for brand new one. so sad
imlazy.2015 - crwdns2934203:0crwdne2934203:0
Yes the screen cracked for me as well… this tutorial is kind of useless.
Thank you HP for making my device unrepairable, you’re on my blacklist now.
I had my Spectre x2 for only 2 years, and the battery was 100% dead, great job!
Bruno - crwdns2934203:0crwdne2934203:0
Where can I purchase the replacement battery?
M. B. Efulaty - crwdns2934203:0crwdne2934203:0
Got a Battery off e-bay and replaced, but something needs to be done for bios to see it. Battery works and says 100% charged, 225% in the control panel icon but the machine hibinates after about 10 mins, wake the machine up sausys 92% charged. Most of the HP diagnostics don’t recognise the battery even thought it works and is installed.
jayre - crwdns2934203:0crwdne2934203:0
thanks for the heads up with the adhesive strips I ran a heatgun @ 100degrees_c along the bottom edge and under the kick stand
used gravity and the adhesive strips melted like butter screen came off no cracks, breaks or problems
Shaun Jaensch - crwdns2934203:0crwdne2934203:0
Replaced the battery without any difficulty. I am now getting a battery not found error. This is the 2nd battery that cannot be recognized. Where can I get a battery that works and is recognized by the computer?
Karl Yockey - crwdns2934203:0crwdne2934203:0
thanks for this course.My spectre X2,has been used 7years,now ,ti couldnt use more than 1 hour.I need replace its baterry.
xinfeng wei - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 13,012
