HP Spectre x2 12-a002dx Back Camera Replacement
  1. HP Spectre x2 12-a002dx Back Camera Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the device is powered off and the kick stand is retracted.
    • The HP Spectre should be placed on a flat surface with the keyboard detached.
  2. HP Spectre x2 12-a002dx Back Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx Back Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx Back Camera Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the screen, there is an entire system of clips which need to be undone as well as 4 Phillips M1.5x2.7 screws.
    • The screws should be removed using a Phillips #000 screwdriver. There is a sticker where the laptop attaches to the keyboard.
    • Heat the sticker (if needed) and use fine point tweezers to grip the sticker and remove it.
  3. HP Spectre x2 12-a002dx Back Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx Back Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx Back Camera Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tools or insert a spudger to begin unclipping the system.
    • Pry the screen off once all the clips have been unclipped.
    • The screen may shatter if not already shattered (beware of flying glass).
    • This screen will break. There is double tape underneath the frame, which is not listed in here.
  4. HP Spectre x2 12-a002dx Back Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx Back Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x2 12-a002dx Back Camera Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the connecting cable of the screen and battery. Use a spudger to reveal the adhesive strip and carefully peel it off.
    • Insert a spudger to the other end and release the ZIF connectors. Detach the cable.
    • While a metal spudger is pictured, use a black nylon spudger instead because it is ESD safe.
  5. HP Spectre x2 12-a002dx Back Camera Replacement, Back Camera: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The HP Spectre X2 Has three Cameras: A front facing webcam( blue arrow), a rear Facing webcam (orange arrow), and a 3d camera (red box). The 3d camera is covered by tape that connects to the heat sink.
  6. HP Spectre x2 12-a002dx Back Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by removing the ribbon that connects the front facing webcam to the motherboard. You can use a black nylon spudger as pictured to do this.
  7. HP Spectre x2 12-a002dx Back Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x2 12-a002dx Back Camera Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The Front facing webcam is secured to the HP spectre by the laptop frame and adhesive on the ribbon cable connecting the camera to the motherboard.
    • To remove the camera, peel back the ribbon cable and then slide the camera down and out of the laptop frame,
  8. HP Spectre x2 12-a002dx Back Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x2 12-a002dx Back Camera Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The rear facing webcam is secured in the same manner as the front.
    • Remove the ribbon connecting the camera to the motherboard, and slide the camera down and out of the laptop frame.
  9. HP Spectre x2 12-a002dx Back Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x2 12-a002dx Back Camera Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next to the webcam is the Led light.
    • To replace the LED camera light, disconnect the ribbon cable from the motherboard. The LED light should slide freely out of the assembly.
    • The black nylon spudger may be used here again.
Talha Bin Amir
crwdns2935283:010/23/17crwdne2935283:0
684 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S10-G6, Thompson Fall 2017 crwdns2935289:0USF Tampa, Team S10-G6, Thompson Fall 2017crwdne2935289:0
USFT-THOMPSON-F17S10G6
crwdns2942667:0crwdne2942667:0 767
