The vent fan keeps the laptop from overheating so the laptop needs to be turned off during this procedure.
Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
Pry up one corner of the bottom case with a spudger.
Work the spudger around the edges, making your way towards the bottom of the laptop.
Remove the bottom case.
Remove the strip of black electrical tape.
Pull the tape away from the vent fan.
Using a Phillips #0 screwdriver, remove the two 40 mm screws securing the fan assembly to the motherboard.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, disconnect the wire connection between the laptop and the vent fan.
Any idea what model# the fan is?
