HP Spectre 13-4002dx SD Card Reader Replacement
  1. HP Spectre 13-4002dx SD Card Reader Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre 13-4002dx SD Card Reader Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx SD Card Reader Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre 13-4002dx SD Card Reader Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx SD Card Reader Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre 13-4002dx SD Card Reader Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre 13-4002dx SD Card Reader Replacement, Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
    • Remove the six 4 mm screws using a Phillips #000 screwdriver.
  4. HP Spectre 13-4002dx SD Card Reader Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre 13-4002dx SD Card Reader Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre 13-4002dx SD Card Reader Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Do not disconnect the cable connector shown in the red box.
    • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
    • Move the cable clear of the battery.
  5. HP Spectre 13-4002dx SD Card Reader Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre 13-4002dx SD Card Reader Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not disconnect the cable connector located in the red box.
    • Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Push the cable to the side so it does not get in the way of the battery removal.
  6. HP Spectre 13-4002dx SD Card Reader Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre 13-4002dx SD Card Reader Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre 13-4002dx SD Card Reader Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the battery cable connector by sliding it out of the socket.
    • Move the battery out of the way if you need more room to disconnect the power cable.
  7. HP Spectre 13-4002dx SD Card Reader Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the battery.
  8. HP Spectre 13-4002dx SD Card Reader Replacement, SD Card Reader: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre 13-4002dx SD Card Reader Replacement, SD Card Reader: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre 13-4002dx SD Card Reader Replacement, SD Card Reader: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The SD Card Port is located in the red box.
    • Remove the one PH0 30 mm screw circled in red.
  9. HP Spectre 13-4002dx SD Card Reader Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the connector outlined in red.
  10. HP Spectre 13-4002dx SD Card Reader Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre 13-4002dx SD Card Reader Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre 13-4002dx SD Card Reader Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To unlock the ribbon cable, lift the white flap on the ZIF connector 90 degrees.
    • Slide the ribbon cable out of the connector.
  11. HP Spectre 13-4002dx SD Card Reader Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SD Card Port.
Cayce Stewart
crwdns2935283:001/16/19crwdne2935283:0
725 crwdns2915208:0crwdne2915208:0
University of Alabama, Team S1-G4, Bedsole Spring 2019 crwdns2935289:0University of Alabama, Team S1-G4, Bedsole Spring 2019crwdne2935289:0
UA-BEDSOLE-S19S1G4
crwdns2942667:0crwdne2942667:0 335
