This guide will aid you in replacing your faulty fan. Make sure you are wearing the Anti-Static Wrist Strap and remove the battery before beginning this guide to avoid any damage to your computer.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
Put on Anti Static Wrist Strap.
Flip Computer Upside down.
Unscrew the eight 3.3mm black screws on the back casing with the T4 Torx Screwdriver.
Use the plastic opening tool to lift the back case off.
Remove the six 2.0mm silver screws and the two 3.2 mm black screws using the PH00 Phillips Screw Head.
Gently unplug from CONO851 plug, using the plastic opening tool.
Gently lift up the battery and remove using the plastic opening tools.
Unscrew three 2.0 mm screws using the Phillips Head #0
Why did you physically remove the battery? It seems like unplugging the battery’s CONO851 plug would be good enough? It’s funny, even in the photo where you remove the fan, the battery is still there.
tshong - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I replaced the fan in my computer. As tshong said, I did not have to remove the battery. Just unplugged it then skipped steps 3 and 5. and voila.
Trach Nguyen - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
