HP Slate 7 4601 Battery Replacement
  1. HP Slate 7 4601 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Slate 7 4601 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin your replacement by using a T3 or T4 Torx screwdriver.
    • Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
    On the HP 10 Plus 2201 there are no head screws. I used the spudger to 'carefully' separate the case. There are little snaps on the inside of case that will separate with little pressure on spudger.
    RB Richter - crwdns2934203:0crwdne2934203:0
    I used these directions to replace HP Plus 10 2201 battery. I bypassed speaker installation.
  2. HP Slate 7 4601 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Slate 7 4601 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the pointed end of the spudger, remove the thin metal band.
    • It is easiest to remove the metal band through the headphone opening.
    On HP 10 Plus 2201 there is no metal band. The case simply unsnaps apart.
  3. HP Slate 7 4601 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Slate 7 4601 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the flat end of the spudger, pry back the rear plastic cover.
    • As you work your way around the edge, several "pop" noises will be made. These noises are caused by the plastic clips coming undone.
    This is basically how I opened my HP 10 Plus 2201. "Using the flat end of the spudger, pry back (apart) the rear plastic cover from tablet.
  4. HP Slate 7 4601 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rear cover.
  5. HP Slate 7 4601 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and remove the yellow tape covering the red and white speaker wires.
    The inside of my HP 10 Plus 2210 looks similar but not exactly as this illustration
    The battery connections weren't the plug in type. The three battery battery wires (red, white, & black) were soldered into place,
  6. HP Slate 7 4601 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Slate 7 4601 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the pointed end of the spudger, push both sides of the speaker wire connector out of its base.
    • Push the same amount on both sides of the connector to avoid jamming or twisting its metal pins.
    • Do not yank or pull on the speaker wires, since they are fragile. Only push on the white connector.
    Do not pull on wires. Never force anything.
    note the route of the speaker cables round the battery
    Alan Boddey - crwdns2934203:0crwdne2934203:0
  7. HP Slate 7 4601 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull back the foil covering the gold charging port ribbon.
    Hpcom Support Helps HP Printer users to download and install All Hp Printers drivers. We also provide all possible solutions to fix hp Printer problems. If you face any issue in install Hp printer driver or having other problems with the hp Printer, you can follow our 100 % working solutions. In case you can’t able to continue printing, then feel free to contact us. We are happy to serve you.
    hpcom us - crwdns2934203:0crwdne2934203:0
  8. HP Slate 7 4601 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Slate 7 4601 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the flat end of the spudger, lift up the black panel covering the charging port connector.
    • Gently slide the charging port ribbon out from its housing.
    • It may be easier to use the pointed end of the spudger than your fingers.
  9. HP Slate 7 4601 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift gold charging strip away from the battery.
  10. HP Slate 7 4601 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Slate 7 4601 Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the white battery connector out of its housing using the pointed end of the spudger.
  11. HP Slate 7 4601 Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the #00 Phillips Head screwdriver, remove the 5 screws holding the battery in place.
    • The four 1.75mm x 3mm silver Phillips Head screws circled in red are interchangeable.
    • The black 1.75mm x 4mm Phillips Head screw must go back to the same spot during reassembly.
  12. HP Slate 7 4601 Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift battery out of its place and set aside.
crwdns2935229:018crwdne2935229:0
Zachary
crwdns2935283:004/14/14crwdne2935283:0
1,453 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-30, Maness Spring 2014 crwdns2935289:0Cal Poly, Team 13-30, Maness Spring 2014crwdne2935289:0
CPSU-MANESS-S14S13G30
Buenas tardes, como están? Consulta, la batería se puede reemplazar por otra genérica, existe algún repuesto?
Javier Sanchez - crwdns2934203:0crwdne2934203:0
Thanx for this amazing demo steps. Sir i need battery of this tab, coz i cant find this battery anywhere then someone told me to go online purchase it wil you so i decided to go online n finally i found ur page so plz arrange me the battery of this tab. My HP Slate 7 battery is not charging . I m from pakistan n my email is aasifbrothers79@gmail.com. Sir i m looking forward for ur kind reply .Thanx
Regards, Asif Sultan
Asif Sultan - crwdns2934203:0crwdne2934203:0
where do i buy the battery in india… there is a site Maxbhi, I ordered the battery, they never send the battery neither returned the money…
Kapil Baidya - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 29,946
