HP ProDesk 400 G5 Mini RAM Replacement / Upgrade
  1. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade, RAM: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade, RAM: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the device around the back is facing you.
    • See the large screw in the center back of the PC.
  2. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the thumbscrew holding the back panel onto the PC.
  3. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the top panel off away from the back of the device.
    • Then, carefully lift it upwards to remove it.
  4. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the main fan to expose the RAM modules.
  5. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingers, pull the metal arms (located on both sides of the RAM module) slightly away from it, to release it from the slot.
    • The RAM will pop up by a few millimeters.
    • Remove it at an angle and not straight up so you don't damage the socket.
  6. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To insert a new RAM stick, line up the indent on the RAM with the indent on the slot, then slide it in.
  7. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the RAM stick down flat once it's securely attached to the socket.
    • You should hear a tactile click which indicates it was installed correctly.
    • Make sure the arms on both sides go back to their locked position.
  8. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After RAM installation, place the fan back on top of the RAM and replace the panel by sliding it into place and tightening it with the thumbscrew.
Sam Manshouri
crwdns2935283:002/01/23crwdne2935283:0
187 crwdns2915208:0crwdne2915208:0
I wish someone wouldcome up with a version of this guide that is the small formfactor pc as the ram is under the space whre the drives are.
chrisblackstone1977 - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 20
crwdns2936753:07crwdne2936753:0 89
crwdns2936753:030crwdne2936753:0 367
crwdns2942667:0crwdne2942667:0 5,845
