HP ProBook x360 11 G5 EE Charging Port Replacement
  1. HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 4.1 mm screws with a T5 Torx screwdriver.
    • Remove the 4.1 mm screws using a JIS #0 screwdriver.
  2. HP ProBook x360 11 G5 EE Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening pick to pry the corners of the keyboard deck.
  3. HP ProBook x360 11 G5 EE Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook x360 11 G5 EE Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook x360 11 G5 EE Charging Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
  4. HP ProBook x360 11 G5 EE Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook x360 11 G5 EE Charging Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook x360 11 G5 EE Charging Port Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the keyboard assembly to expose two ribbon cables.
    • Lift the two plastic tabs that hold the cables in place on the motherboard
    • Slide the ribbon cables out of each connector.
  5. HP ProBook x360 11 G5 EE Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook x360 11 G5 EE Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the keyboard assembly from the rest of the computer.
  6. HP ProBook x360 11 G5 EE Charging Port Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook x360 11 G5 EE Charging Port Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 3 mm screws from the battery with the JIS #0 screwdriver.
  7. HP ProBook x360 11 G5 EE Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook x360 11 G5 EE Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook x360 11 G5 EE Charging Port Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the battery up from the laptop using an opening pick.
    • Lift the battery out of its place.
  8. HP ProBook x360 11 G5 EE Charging Port Replacement, Charging Port: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook x360 11 G5 EE Charging Port Replacement, Charging Port: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single 3 mm screw from the charging port using a T5 Torx screwdriver.
  9. HP ProBook x360 11 G5 EE Charging Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook x360 11 G5 EE Charging Port Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook x360 11 G5 EE Charging Port Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the charging port wire from the motherboard.
    • Remove the charging port from your device.
Michelle Pina
crwdns2935283:010/26/21crwdne2935283:0
506 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-4, Pee Fall 2021 crwdns2935289:0Gateway, Team 1-4, Pee Fall 2021crwdne2935289:0
GCC-PEE-F21S1G4
Hi!! I have the same model of notebook with 64 giga emmc. Is it possible installing an ssd or an hdd?
Riccardo Insolera - crwdns2934203:0crwdne2934203:0
I followed each and every step, and realised a little too late that my laptop is a HP ProBook x360 11 G1 -and not a G5. The G1 requires the ability to de-solder the built in charging port.
On step 6, I noticed there were 6 screws holding the battery in, not 4.
Then on step 9, I noticed that the charging port is actually soldered to the motherboard and there is no visible cable attaching it to the board which can be unhooked.
Sam T - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 1,432
