HP ProBook 640 G1 Midframe Replacement
  1. HP ProBook 640 G1 Midframe Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop upside down to show the battery lock slider.
    • It is a black slider near the top, with a battery logo to the left and a lock sign to the right.
  2. HP ProBook 640 G1 Midframe Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery slider all the way to the left, towards the battery symbol.
    • You may also need to slide the other slider to the right of the battery slider, as shown in the picture.
  3. HP ProBook 640 G1 Midframe Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery by sliding it away from the laptop while holding the battery locker.
    • The battery should slide out with ease.
  4. HP ProBook 640 G1 Midframe Replacement, Back Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 640 G1 Midframe Replacement, Back Panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide down and pull up on the cover to remove it.
  5. HP ProBook 640 G1 Midframe Replacement, Midframe: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 640 G1 Midframe Replacement, Midframe: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 640 G1 Midframe Replacement, Midframe: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight rubber screw plugs from the bottom and the two rubber screw plugs from the sides of the laptop using a paperclip.
    • Remove the fourteen 6 mm screws from the bottom of the laptop and the two 6 mm screws from the sides using a T8 Torx screwdriver.
    • Remove the six 4 mm screws that secure the midframe using a T8 Torx screwdriver.
    • Some of the screws are held in place by springs and cannot be fully removed, but can still be loosened.
  6. HP ProBook 640 G1 Midframe Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 640 G1 Midframe Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the disk drive by gently pulling it out.
    • Remove the two 3 mm screws using a Phillips #1 screwdriver.
    • Only one screw is visible in the photo the second screw is located directly above it.
  7. HP ProBook 640 G1 Midframe Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 640 G1 Midframe Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull up on the midframe, gripping it from the inside.
    • This may take a small amount of force. If it feels stuck, check for missed screws. Go back to the previous steps and make sure you have removed all necessary screws.
Carter Wilcomb
crwdns2935283:011/04/25crwdne2935283:0
199 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-2, Biswokarma Fall 2025 crwdns2935289:0UMass Dartmouth, Team 4-2, Biswokarma Fall 2025crwdne2935289:0
UMASSD-BISWOKARMA-F25S4G2
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 299
