HP ProBook 455 G1 DVD/CD Drive Replacement
  1. HP ProBook 455 G1 DVD/CD Drive  Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
    • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
  2. HP ProBook 455 G1 DVD/CD Drive  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the two battery release latches towards the center of the laptop to release the battery.
  3. HP ProBook 455 G1 DVD/CD Drive  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 455 G1 DVD/CD Drive  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tilt the battery upward.
    • Remove it from the laptop.
  4. HP ProBook 455 G1 DVD/CD Drive  Replacement, Service Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the two release latches that were mentioned in the battery removal process to release the service panel.
  5. HP ProBook 455 G1 DVD/CD Drive  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 455 G1 DVD/CD Drive  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the service panel toward you using your thumbs.
    • Lift it to remove the panel and reveal inner components of the computer.
  6. HP ProBook 455 G1 DVD/CD Drive  Replacement, DVD/CD Drive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 455 G1 DVD/CD Drive  Replacement, DVD/CD Drive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips P0 Screwdriver, remove the 6 millimeter screw that secures the DVD/CD drive to the computer.
    • It will be located in the upper left section of the computer, housed in a small square hole in the computer frame.
    • The Phillips head screwdriver is the screwdriver with a "+" shaped tip. P0 refers to the name/size of this particular Phillips head screwdriver.
  7. HP ProBook 455 G1 DVD/CD Drive  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the screwdriver, gently push the silver tab that the screw secured to the left to release the DVD/CD drive from the computer.
  8. HP ProBook 455 G1 DVD/CD Drive  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The DVD/CD drive will be extended from the side of the laptop. Slowly remove it from the computer.
Jennifer Sexton
crwdns2935283:003/18/18crwdne2935283:0
649 crwdns2915208:0crwdne2915208:0
Baylor, Team S5-G1, Williams Spring 2018 crwdns2935289:0Baylor, Team S5-G1, Williams Spring 2018crwdne2935289:0
BU-WILLIAMS-S18S5G1
crwdns2942667:0crwdne2942667:0 1,092
