HP ProBook 4540s WLAN Module Replacement
    1. HP ProBook 4540s WLAN Module Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
      • Slide the two release latches on either side of the battery.
      • Gently tilt the battery upward and remove it from its socket.
    1. HP ProBook 4540s WLAN Module Replacement, Bottom Door: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the computer so the bottom is facing towards you.
      • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
      • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
      • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
    1. HP ProBook 4540s WLAN Module Replacement, WLAN Module: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 4540s WLAN Module Replacement, WLAN Module: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the antenna cables from their terminals in the WLAN module.
      • One cable is attached to the Auxiliary ("Aux") terminal, represented with a blue wire. The other cable is connected to the Main terminal which is usually represented with a red wire. These wires can be seen in little windows beside the component.
    2. HP ProBook 4540s WLAN Module Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 4540s WLAN Module Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew two 3.0 mm Phillips PM2.0x3.0 screw securing the module to the computer.
      • The edge of the module that is opposite of the slot is risen away from the computer.
      • Gently lift and remove the module.
Amber Schindler
crwdns2935283:010/26/16crwdne2935283:0
1,144 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team 1-5, Rose Fall 2016 crwdns2935289:0UW Tacoma, Team 1-5, Rose Fall 2016crwdne2935289:0
UWT-ROSE-F16S1G5
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 2,511
