HP ProBook 450 G4 Fan Replacement
  1. HP ProBook 450 G4 Fan Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 450 G4 Fan Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power your laptop off.
    • Flip the laptop over.
    • Orient the laptop so the two vents on the bottom face upward and are further away from you.
  2. HP ProBook 450 G4 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
    • Use the spudger to separate the vent panel from the laptop.
    • Slide the vent panel off the backside of the laptop.
  3. HP ProBook 450 G4 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
  4. HP ProBook 450 G4 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to lift the left side of the hard drive up.
    • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
  5. HP ProBook 450 G4 Fan Replacement, Keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 450 G4 Fan Replacement, Keyboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 450 G4 Fan Replacement, Keyboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
    • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
  6. HP ProBook 450 G4 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
    • Apply pressure to the black tabs until they release and pop out.
  7. HP ProBook 450 G4 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the laptop so the keyboard is facing upwards and towards you.
    • Insert the spudger in between the edge of the keyboard and the computer frame.
    • Slide the spudger around the edge of the keyboard until the keyboard is loose.
    • Gently pull the keyboard away from the body of the laptop.
    • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
  8. HP ProBook 450 G4 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently lift up the black locking bar on the keyboard connector.
    • Slide the keyboard ribbon out of the connector.
    • Remove the keyboard.
    • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
  9. HP ProBook 450 G4 Fan Replacement, Battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 450 G4 Fan Replacement, Battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop back over.
    • Remove the eight 6.8mm T8 Torx screws on the backside of the laptop.
  10. HP ProBook 450 G4 Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the three 6.6mm screws from the upper left corner of the laptop.
  11. HP ProBook 450 G4 Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to slide the disk drive out of the laptop.
    • Use the Phillips #0 screwdriver to remove the two 3.2mm screws that are underneath where the disk drive previously was.
  12. HP ProBook 450 G4 Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the two 6.6mm screws.
  13. HP ProBook 450 G4 Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop back over so it is facing upwards.
    • Remove the six 6.6mm T8 Torx screws underneath where the keyboard used to be.
  14. HP ProBook 450 G4 Fan Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to disconnect the nine cable connectors that secure the top case of the laptop to the body of the laptop.
    • Be extra careful while disconnecting the cable connectors because they can tear easily.
  15. HP ProBook 450 G4 Fan Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the spudger in between the top case of the laptop and its outer frame.
    • Slide the spudger around the edge of the laptop until the top case comes off.
    • Remove the top case.
  16. HP ProBook 450 G4 Fan Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the opening tool underneath the left side of the battery to remove it from the laptop.
  17. HP ProBook 450 G4 Fan Replacement, Fan: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 450 G4 Fan Replacement, Fan: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 450 G4 Fan Replacement, Fan: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to disconnect the two cable connectors that secure the fan to the laptop.
  18. HP ProBook 450 G4 Fan Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the spudger underneath the black wire that wraps over the top of the fan.
    • Use the spudger to pull the black wire away from the top of the fan.
  19. HP ProBook 450 G4 Fan Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 450 G4 Fan Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a TR9 Torx screwdriver to remove the 6.6mm black screw directly above the fan.
  20. HP ProBook 450 G4 Fan Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the spudger under the right side of the fan.
    • Use the spudger to gently lift the fan from the laptop.
crwdns2935229:05crwdne2935229:0
Sebastian Dow
crwdns2935283:001/23/20crwdne2935283:0
1,058 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G3, White Winter 2020 crwdns2935289:0Cal Poly, Team S1-G3, White Winter 2020crwdne2935289:0
CPSU-WHITE-W20S1G3
crwdns2935297:018crwdne2935297:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 3,131
