HP ProBook 450 G4 Display Assembly Replacement
  1. HP ProBook 450 G4 Display Assembly Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 450 G4 Display Assembly Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off your laptop and flip it over so that the bottom faces upward.
    • Use the Phillips #0 screwdriver to remove the screw securing the service door.
    • Use a Jimmy to remove the service door.
  2. HP ProBook 450 G4 Display Assembly Replacement, Display Assembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 450 G4 Display Assembly Replacement, Display Assembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the two 6.6mm screws.
    • Remove the black 3.2mm screw that secures the hard drive to the left side of the laptop with a Phillips #0 screwdriver.
    • Use the spudger to lift the left side of the hard drive, and remove.
  3. HP ProBook 450 G4 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 450 G4 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all 6.6 mm T8 Torx screws, including where the hard drive used to be.
  4. HP ProBook 450 G4 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 450 G4 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unclip the wires from the Wi-Fi card.
    • Remove the Wi-Fi card.
  5. HP ProBook 450 G4 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 450 G4 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 450 G4 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop over, and use a Jimmy to loosen the keypad from the laptop.
    • Use the spudger to unclip the tab.
    • Remove the top case once all tabs are loose.
  6. HP ProBook 450 G4 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to disconnect the black wire.
  7. HP ProBook 450 G4 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 450 G4 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the two 3.2mm screws from the hinges.
    • Repeat on both sides.
  8. HP ProBook 450 G4 Display Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove and replace the display assembly.
Nat Robinson
crwdns2935283:002/08/24crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 5-3, Coppersmith Spring 2024 crwdns2935289:0University of North Texas, Team 5-3, Coppersmith Spring 2024crwdne2935289:0
UNT-COPPERSMITH-S24S5G3
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 343
