HP ProBook 440 G9 Trackpad Replacement
  1. HP ProBook 440 G9 Trackpad Replacement, Remove Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 440 G9 Trackpad Replacement, Remove Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use Phillips #01 screwdriver to unscrew all 6 threaded screws.
    • Do not remove screws from bottom cover as they are intended to stay attached to the bottom cover.
    • Use guitar pick tool to unclip the back cover all around the edges starting from the top.
  2. HP ProBook 440 G9 Trackpad Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 440 G9 Trackpad Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 440 G9 Trackpad Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all 4 screws from the battery.
    • Disconnect the Battery Connector from the motherboard using the side tabs on the connector.
    • Possible spark may occur at the Battery Connector port if laptop is not fully powered off when replacing the laptop battery.
    • Remove the battery from the laptop.
  3. HP ProBook 440 G9 Trackpad Replacement, Detach Trackpad: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 440 G9 Trackpad Replacement, Detach Trackpad: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 440 G9 Trackpad Replacement, Detach Trackpad: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew 4 screws with Phillips #01 screwdriver.
    • Unscrew 2 screws with the Phillips #00 screwdriver.
    • Unlatch the trackpad connector.
    • Pull the tab on the trackpad ribbon straight out from the connector.
    • Trackpad ribbon cable can be easily damaged.
  4. HP ProBook 440 G9 Trackpad Replacement, Remove Trackpad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 440 G9 Trackpad Replacement, Remove Trackpad: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 2 silver tape attached to the trackpad frame.
    • Try to not tear tape strips but does not affect trackpad performance if they are damaged.
    • Remove trackpad from laptop frame.
Joel
crwdns2935283:004/30/18crwdne2935283:0
470 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 213
