HP ProBook 440 G9 Solid State Drive Replacement
  1. HP ProBook 440 G9 Solid State Drive Replacement, Remove Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 440 G9 Solid State Drive Replacement, Remove Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use Phillips #01 screwdriver to unscrew all 6 threaded screws.
    • Do not remove screws from bottom cover as they are intended to stay attached to the bottom cover.
    • Use guitar pick tool to unclip the back cover all around the edges starting from the top.
  2. HP ProBook 440 G9 Solid State Drive Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 440 G9 Solid State Drive Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 440 G9 Solid State Drive Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all 4 screws from the battery.
    • Disconnect the Battery Connector from the motherboard using the side tabs on the connector.
    • Possible spark may occur at the Battery Connector port if laptop is not fully powered off when replacing the laptop battery.
    • Remove the battery from the laptop.
  3. HP ProBook 440 G9 Solid State Drive Replacement, Remove Solid State Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ProBook 440 G9 Solid State Drive Replacement, Remove Solid State Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ProBook 440 G9 Solid State Drive Replacement, Remove Solid State Drive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use Phillips #00 to remove screw from SSD.
    • SSD will lift up at a 45 degree angle when screw is removed.
    • Remove SSD from the SSD slot.
    • When reinserting the SSD plug in at a 45 degree angle and then screw down with the new screw.
Joel
crwdns2935283:004/30/18crwdne2935283:0
470 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 556
