If your computer is running slowly or not downloading as quickly as you would like, replace the RAM card to an upgraded version.
Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
Slightly push up while lifting up on the power button panel to release the panel.
Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
Carefully (holding both sides of the keyboard), push up and lift slightly.
Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
Use the black spudger to lift the black latch holding the keyboard ribbon cable.
Press the two prongs outward, and the RAM card will come out of PCI Express connector.
crwdns2935229:05crwdne2935229:0
