HP ProBook 4320t Processor Heat Sink Replacement Guide
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Battery Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 4320t Processor Heat Sink Replacement Guide, Battery Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide, Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 4320t Processor Heat Sink Replacement Guide, Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
    3. HP ProBook 4320t Processor Heat Sink Replacement Guide, Flip: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip laptop over and open it.
    4. HP ProBook 4320t Processor Heat Sink Replacement Guide, Push N Lift: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slightly push up while lifting up on the power button panel to release the panel.
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Unscrewing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide, Careful Now: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 4320t Processor Heat Sink Replacement Guide, Careful Now: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully (holding both sides of the keyboard), push up and lift slightly.
      • Keyboard is still connected via a ribbon cable.
      • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
    3. HP ProBook 4320t Processor Heat Sink Replacement Guide, Disconnect Wire: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Unscrew: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide, Slide the Panel Off: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully slide the bottom panel to the right.
      • Keyboard is connected via a wire to the back of the panel.
    3. HP ProBook 4320t Processor Heat Sink Replacement Guide, Lift up Carefully: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
      • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
    4. HP ProBook 4320t Processor Heat Sink Replacement Guide, Disconnect Wire: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Computer Fan: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate silver holding panel on the left side of the computer.
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the five silver (2.5 mm Phillips) screws that are holding the panel in.
      • Unscrew the two black (3.0 mm Phillips) screws that are holding the panel in.
    3. HP ProBook 4320t Processor Heat Sink Replacement Guide: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove holding panel and put aside.
    4. HP ProBook 4320t Processor Heat Sink Replacement Guide: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the red, black, and blue ribbon cable connector using the black spudger.
    5. HP ProBook 4320t Processor Heat Sink Replacement Guide: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the one (2.0 mm Phillips) screw holding in the fan.
    6. HP ProBook 4320t Processor Heat Sink Replacement Guide: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift fan up carefully and replace.
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Processor Heat Sink: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the four (2.5 mm Phillips) screws holding the processor heat sink in (located near the center of the laptop)
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift slightly on the main component of the heat sink and slowly pull in towards the center (to your right) to free the heat sink.
Eric Markham
crwdns2935283:008/29/14crwdne2935283:0
227 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-5, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 9-5, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S9G5
crwdns2935297:030crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,426
