HP ProBook 4320t Clock Battery Replacement Guide
  1. HP ProBook 4320t Clock Battery Replacement Guide, Battery Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 4320t Clock Battery Replacement Guide, Battery Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Clock Battery Replacement Guide, Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 4320t Clock Battery Replacement Guide, Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Clock Battery Replacement Guide, Flip: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip laptop over and open it.
  4. HP ProBook 4320t Clock Battery Replacement Guide, Push N Lift: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Clock Battery Replacement Guide, Unscrewing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Clock Battery Replacement Guide, Careful Now: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 4320t Clock Battery Replacement Guide, Careful Now: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Clock Battery Replacement Guide, Disconnect Wire: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t Clock Battery Replacement Guide, Unscrew: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
  9. HP ProBook 4320t Clock Battery Replacement Guide, Slide the Panel Off: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
  10. HP ProBook 4320t Clock Battery Replacement Guide, Lift up Carefully: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
  11. HP ProBook 4320t Clock Battery Replacement Guide, Disconnect Wire: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
  12. HP ProBook 4320t Clock Battery Replacement Guide, Detach Cables: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the black spudger, detach the two antenna cable connectors leading to the Wi-Fi card (this is to access the clock battery without causing damage to the cords).
  13. HP ProBook 4320t Clock Battery Replacement Guide, Pop it Out: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your black spudger, gently press down and towards you until the battery slides out.
    • Put new clock battery in and reassemble.
Joshua
crwdns2935283:009/23/14crwdne2935283:0
134 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-5, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 9-5, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S9G5
crwdns2942667:0crwdne2942667:0 1,128
