HP ProBook 4320t Clock Battery Replacement Guide
crwdns2869540:0crwdne2869540:0: 1.7천
2
13
67
1,664
crwdns2955950:0crwdne2955950:0: 1
crwdns2960002:01crwdne2960002:0.
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 2
crwdns2959982:02crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 5 - 10 crwdns2931279:0crwdne2931279:0
The clock battery is nessary for the internal clock to maintain the correct time. If the battery is dead, and you are not connected to the internet, your computer clock will be misleading.
    1. HP ProBook 4320t Clock Battery Replacement Guide, Battery Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 4320t Clock Battery Replacement Guide, Battery Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
    2. HP ProBook 4320t Clock Battery Replacement Guide, Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 4320t Clock Battery Replacement Guide, Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
    3. HP ProBook 4320t Clock Battery Replacement Guide, Flip: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip laptop over and open it.
    4. HP ProBook 4320t Clock Battery Replacement Guide, Push N Lift: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slightly push up while lifting up on the power button panel to release the panel.
    1. HP ProBook 4320t Clock Battery Replacement Guide, Unscrewing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
    2. HP ProBook 4320t Clock Battery Replacement Guide, Careful Now: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ProBook 4320t Clock Battery Replacement Guide, Careful Now: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully (holding both sides of the keyboard), push up and lift slightly.
      • Keyboard is still connected via a ribbon cable.
      • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
    3. HP ProBook 4320t Clock Battery Replacement Guide, Disconnect Wire: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
    1. HP ProBook 4320t Clock Battery Replacement Guide, Unscrew: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
    2. HP ProBook 4320t Clock Battery Replacement Guide, Slide the Panel Off: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully slide the bottom panel to the right.
      • Keyboard is connected via a wire to the back of the panel.
    3. HP ProBook 4320t Clock Battery Replacement Guide, Lift up Carefully: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
      • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
    4. HP ProBook 4320t Clock Battery Replacement Guide, Disconnect Wire: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
    1. HP ProBook 4320t Clock Battery Replacement Guide, Detach Cables: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the black spudger, detach the two antenna cable connectors leading to the Wi-Fi card (this is to access the clock battery without causing damage to the cords).
    2. HP ProBook 4320t Clock Battery Replacement Guide, Pop it Out: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your black spudger, gently press down and towards you until the battery slides out.
      • Put new clock battery in and reassemble.
Joshua
crwdns2935283:009/23/14crwdne2935283:0
134 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-5, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 9-5, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S9G5
crwdns2935297:0120crwdne2935297:0
crwdns2936753:030crwdne2936753:0 67
crwdns2959996:0crwdne2959996:0 1,664
