HP Prime Graphing Calculator G8X92A Battery Replacement
  1. HP Prime Graphing Calculator G8X92A Battery Replacement, Prerequisites: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power down the device.
    • Flip the device face side down so the back of the device is facing up.
  2. HP Prime Graphing Calculator G8X92A Battery Replacement, Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Prime Graphing Calculator G8X92A Battery Replacement, Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Prime Graphing Calculator G8X92A Battery Replacement, Disassembly: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the two 4.5 mm screws securing the battery cover located at the bottom center of the device.
    • Remove the cover.
  3. HP Prime Graphing Calculator G8X92A Battery Replacement, Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Prime Graphing Calculator G8X92A Battery Replacement, Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Prime Graphing Calculator G8X92A Battery Replacement, Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery.
To reassemble your calculator, follow these instructions in reverse order. Power on the Calculator to make sure it works.
Eric A Bidema
crwdns2935283:009/16/20crwdne2935283:0
449 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S2-G15, Eggleston Fall 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S2-G15, Eggleston Fall 2020crwdne2935289:0
CMCSC-EGGLESTON-F20S2G15
The link to the battery in the "what you need" section is not correct. The battery is the same as the Samsung Galaxy S3. It has dimensions of approximately 50mmx63mmx5.5mm, with a 4-terminal connector on the top. it is 3.7VDC/7.4Wh. The one that comes with the calculator is "rated" at 2000mAh (whatever that means these days, as battery specs are often works of fiction).
m_a_s - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 6,715
