HP Photosmart c3180 Scanner Bulb Replacement
  1. HP Photosmart c3180 Scanner Bulb Replacement, Top Panel of HP Photosmart c3180 printer: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart c3180 Scanner Bulb Replacement, Top Panel of HP Photosmart c3180 printer: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before disassembling your printer, be sure that the printer has been unplugged to avoid any risk of injury.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
    Änderung des Textes: die kleine Lasche verriegelt die kleine Frontblende: mit leichtem Druck Richtung “rechte Druckerseite entriegeln, gleichzeitig jene Blende nach vorn lösen.
    Garofalo - crwdns2934203:0crwdne2934203:0
  8. HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the top panel of the printer away from the printer body.
    nur die dünne weiße Abdeckung, die graue bleibt noch; zuerst hinten anheben, vorn ist mittig eine Nase zu lösen.
  10. HP Photosmart c3180 Scanner Bulb Replacement, Scanner Bulb: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart c3180 Scanner Bulb Replacement, Scanner Bulb: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Set aside the top panel of the printer.
    • Lift the scanner carriage vertically, being careful not to yank of the cables connecting it to the printer.
  11. HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the scanner carriage over to expose the connectors on the bottom.
    • Carefully remove the small cable from the connector.
    • Carefully remove the large cable from the connector.
  12. HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart c3180 Scanner Bulb Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the scanner carriage from the scanner tray and flip it upside down.
    • Remove the two T10 12mm Torx screws.
    • Remove the scanner carriage from the scanner bulb.
Jim
crwdns2935283:010/06/11crwdne2935283:0
1,623 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-30, Maness Fall 2011 crwdns2935289:0Cal Poly, Team 20-30, Maness Fall 2011crwdne2935289:0
CPSU-MANESS-F11S20G30
crwdns2935297:025crwdne2935297:0
You say no parts needed to be purchased. You have to buy a new scanner bulb if you’re replacing it.
ddaviddierlam - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 6,276
