HP Photosmart Premium C309g Scanner Replacement
  1. HP Photosmart Premium C309g Scanner Replacement, Scanner: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the top of the printer. The printer should appear as shown.
  2. HP Photosmart Premium C309g Scanner Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart Premium C309g Scanner Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the blue plastic opening tool to pry the trim pieces all the way around the printer.
    • Loosen the pieces around the edges before pulling to remove from the printer.
    • Pull the (4) trim pieces off and set them aside.
  3. HP Photosmart Premium C309g Scanner Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart Premium C309g Scanner Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the blue plastic opening tool, pull from the middle and then slide back to remove the side panels.
    • The side trim pieces need to be removed before the front trim pieces.
  4. HP Photosmart Premium C309g Scanner Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the T9 Torx Security screwdriver bit, unscrew the five 12mm screws shown.
  5. HP Photosmart Premium C309g Scanner Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
    • Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
    • Both clips will come unattached and you can set the scanner flap aside.
  6. HP Photosmart Premium C309g Scanner Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the scanner glass piece from the printer and set it aside.
  7. HP Photosmart Premium C309g Scanner Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart Premium C309g Scanner Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pick up the scanner piece as shown to see the bottom side and wiring.
  8. HP Photosmart Premium C309g Scanner Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart Premium C309g Scanner Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the 2 wire ribbons shown by pulling them away from the scanner piece.
Charles
crwdns2935283:010/23/14crwdne2935283:0
401 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team 1-2, Lauer Fall 2014 crwdns2935289:0Michigan Tech, Team 1-2, Lauer Fall 2014crwdne2935289:0
MTU-LAUER-F14S1G2
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,414
